Re: 660 weight and horsepower
Posted by mkirsch on March 07, 2011 at 07:50:13 from (67.253.216.24):
In Reply to: 660 weight and horsepower posted by abartholomew on March 07, 2011 at 05:15:52:
The tractor is going to be FAST with the 2400RPM engine in it, not necessarily more powerful.
The 560's gearing is designed for 1800RPM, so everything including the PTO will be running 33% faster with the 2400RPM engine.
For field work, if you run in the same gear and the same engine RPM as before, you won't notice any power increase unless this engine is in a whole lot better shape than the one you're replacing.
You'll have to drop down a gear if you want to take advantage of the extra power from the extra RPMs.
