Re: Farmall M Loader Weirdness
Posted by Janicholson on March 07, 2011 at 14:39:01 from (199.17.6.194):
In Reply to: Farmall M Loader Weirdness posted by big a on March 07, 2011 at 10:58:10:
Roger may be correct.
If the lift cylinders are double acting, with ports on both ends, the upper ends need to have small air vents screwed into them (to keep them clean but allow air to get out) or the upper ports can be hosed to the drain of the Liftall with a cross fitting and a close nipple. this allows the upper cylinder volume to add to the total reservoir volume. Jim
