Re: Farmall 450 Tranmission cleaning
Posted by Baelee05 on March 07, 2011 at 15:50:50 from (12.192.13.220):
In Reply to: Re: Farmall 450 Tranmission cleaning posted by Tony_Idaho on March 07, 2011 at 13:59:59:
Here is what I would do if it were mine. I would drain the oil and then add about 5 gallons of diesel fuel. Drive it around a little while and drain it. As cruddy as your shift rails look I would take the deck off the transmission and see what everything else looks like. You might need to scrape some of the gunk loose and use an old paint brush with solvent or diesel fuel to clean things up. Those shift rails show signs of a lot of moisture. I question what condition some of the bearings might be in.
