Re: 400 lp head
Posted by Wardner on March 07, 2011 at 19:18:41 from (209.86.226.56):
In Reply to: 400 lp head posted by Whiskey Bent on March 07, 2011 at 17:54:30:
If D Slater doesn't answer this thread, I'll try to take his place, but with less precision.
Most of the 400 LP heads are the same as the gasoline heads. You need a 450 LP head to have something special and valuable. I think that some of the very last 400s used the special head.
My W-400 LP with serial number 1723 uses the gasoline head.
Goto the CaseIH parts site to get the appropriate casting numbers.
