Re: Super M and disc
Posted by CNKS on March 08, 2011 at 05:05:52 from (216.144.104.128):
In Reply to: Super M and disc posted by Farmallzach on March 07, 2011 at 20:37:43:
Sure, if theres no weight on it -- won't go in the ground either. If you want penetration, 7-8 ft is about it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
