Re: M. Clutch
Posted by WY JERRY on March 08, 2011 at 06:52:04 from (72.21.73.208):
In Reply to: M. Clutch posted by Baelee05 on March 07, 2011 at 19:37:21:
If the belly pump is out, it would be easy to remove the belly cover and take a look inside to see how much oil / grease is around. You wont see the plates, but can see the throw out bearing assembly and shaft spline. If it looks oily or rusty you may have to take the clutch out and clean it up.
Jerry
