Re: Strange but true!! (Farmall h)
Posted by Kippster on March 09, 2011 at 04:00:12 from (24.144.201.222):
In Reply to: Re: Strange but true!! (Farmall h) posted by teddy52food on March 08, 2011 at 20:29:11:
I took the mag out of the engine to dry it out. It got wet and had no fire. When I poked it back in, I must have put it in 180 degrees from where I had it before and actually got it back the way it should be. Then it was a matter of changing the wires to their correct locations.
