Re: using a TA properly
Posted by MN Mike on March 09, 2011 at 08:52:37 from (216.77.154.39):
In Reply to: using a TA properly posted by jstalk on March 09, 2011 at 08:03:39:
others with more experience will chime in but I never use the TA going downhill. that burns them up quick. I use my TA when working in the field to get RPMs back up when the pulling gets hard. think of it as a downshift without using the clutch. I've also used my TA to slow down before turning around on the field - not sure how much wear that causes. Finally, Grandpa said never touch them in the winter after he replaced TA #2.
