Re: 1-1/4 X 1-1/4 solid bar stock
Posted by Rootsy on March 09, 2011 at 09:35:50 from (24.247.111.162):
In Reply to: 1-1/4 X 1-1/4 solid bar stock posted by CNKS on March 08, 2011 at 19:23:39:
A 1 1/4 sq tube with a 3/16 wall thickness is about 66% as stiff as a solid 1 1/4" bar - Assuming both are similar materials with similar strength properties and modulus of elasticity.
As an example, a 48" long piece of say 1 1/4 sq solid A36 , fixed at one end with a 1000 lb distributed load deflects 2.22 inches at the end. A mild steel 1 1/4 sq x .19 wall tube deflects 3.31 inches under the same constraint and loading.
