Re: IH 340 torque specs
Posted by horsepoor on March 09, 2011 at 12:34:06 from (208.124.126.217):
In Reply to: IH 340 torque specs posted by Chuck Heck on March 09, 2011 at 11:01:01:
The 340 used the C-135 gasoline or D-166 diesel four cylinder engines as their powerplants.
Cylinder heads: Torque 80-90 ft.-lbs for the C-135
Torque 110-120 ft.-lbs for the D-166
Rods: Tighten to 43-49 ft.-lbs for the C-135
Tighten to 40-50 ft.-lbs for the D-166
Mains: Tighten the mains to 75-80 ft.-lbs for the C-135
Tighten the mains to 75-85 ft.-lbs for the D-166
This is from my I&T IH-201 shop manual. This site has them, and I would recommend getting one before you get started.
