If thats a new radiator they ordered for you, I didn't know anyone made a low pressure one anymore. Makes me wonder what you had to start with. If the radiator shop was wrong about the radiator being for a M, SM theres the possibility the 400 had a late model IH replacement radiator with a smaller cap than the standard pressure type one. If the radiator you removed had the fill cap above a non molested grill, it wasn't a SM one. If the cap was above a unmolested grill hood to start with, I would say you had a 400 one to start with. Did the radiator you removed have a bigger hole for the steering shaft to pass through than the replacement? What I'm getting at is you could have a radiator with a bigger cap now and its still not a low pressure radiator. If you have a low pressure opening on the radiator fill the gas cap is the same size. Does the gas cap look the same size as the radiator opening? Bottom line is a radiator for a M or SM is going to leave the fill cap below the grill hood level. Some aftermarket radiators put a longer neck on the top to come above the hood. Original IH 400 radiators used a taller top radiator tank with a standard length neck.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
