Re: Farmall M Loader Weirdness
Posted by big a on March 09, 2011 at 18:20:46 from (166.231.84.70):
In Reply to: Farmall M Loader Weirdness posted by Janicholson on March 07, 2011 at 10:58:10:
Pretty sure you are onto something there Jim. Problem seems to.be on the RH cylinder. At full extension, removed from the loader, it leaed like a sieve at the shaft seal, and I hear something rattling inside. I suspect its blocking oil return flow. Things work normally with just LH side connected.
Any idea if those inline delay valves are available, or where a suitable replacement can be found? Controlling rate of drop is a bit scary without them.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
