Re: 12V conversion question
Posted by Bob on March 09, 2011 at 19:58:32 from (173.226.56.4):
In Reply to: 12V conversion question posted by Brad Gyde on March 09, 2011 at 19:35:36:
If going 12 Volt, WHY not go to (-) ground, 'cause sooner or later someone's gonna see that 12 Volt battery and boost it or charge it (-) ground, like every other 12 Volt battery they've ever seen.
If a magneto, NOTHING needs to be changed in the switchbox, 'cept the wires on the ammeter IF you do go to (-) ground.
If a distributor ignition system, you'll have to add a dropping resistor ahead of the coil or go to a TRUE 12 Volt coil, NAPA IC14SB, for example.
Battery ignition coil... (-) side goes to distributor, if (-) ground, (+) side of coil to distributor, if (+) ground.
