Re: Getting boned by radiator shop
Posted by Owen Aaland on March 09, 2011 at 21:05:28 from (207.13.114.138):
In Reply to: Getting boned by radiator shop posted by Bugspot on March 09, 2011 at 14:24:06:
The non pressure radiator has no lip inside the filler opening for a cap to seal on. It uses the same type of cap as the fuel tank.
There are two different size openings for pressurized radiators. The original M style uses a cap with a 2" seal. The cap will have an arm attached to it.
The later IH tractors used a cap with a 1 1/2" seal. The IH cap for that style was squared off. There are also two different depths of sealing lips.
If you look up the radiator for a 400 on this site you can see the difference in the top tank and filler neck length.
