I think thats pretty good compresion up and down a little but you dont have any below 100. Is the tractor burning really rich by chance. Like does it always smoke black like its getting to much gas? Thats what mine was doing and it would fouwl up the plugs in no time. The only way i could fix mine is to remove the electric seliniod valve on the bottom of the carb and replace it with an adjustible jet. After changing the plugs agian it ran great.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
