All wiring is fine to use as is. The insulation should be checked to assure it is not cracked or worn through at any point, but the 12volts will put less amps through the wires, making it easier on them. As it is a mag, there is no issue other than lights. Do it your way. Sense it probably had a 4 position light switch, make sure that the new wiring of a voltage regulator does not use that part of the light switch formerly used for the generator charge rate control. It is a direct ground or ground through a resistor that is connected to the field terminal of the gen in its former setup. The field terminal now connects only to the Field terminal of the new regulator. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
