Re: Farmall A compression
Posted by GriffNC on March 10, 2011 at 08:54:48 from (71.53.107.175):
In Reply to: Farmall A compression posted by Randy McClena on March 10, 2011 at 08:47:44:
Randy , you can not tell much of anything turning that engine by hand . But feeling compression by doing that tells me you do have compression, HOWEVER you can not make a good decision about the need for a rebuild unless you do a proper compression check .
You can rent a compression gauge from several of the parts suppliers .
If tractor was running and no smoke ----I would not worry about weld in block , I would clean her up and work her red off !!!
