Posted by rustred on March 10, 2011 at 09:07:53 from (74.200.18.155):
In Reply to: Farmall A compression posted by Randy McClena on March 10, 2011 at 08:47:44:
cleaned head and valves? did you remove valves if did , must be replaced in same guide it came out of. when looking at valves need to know what to look for, like the seat and so on. turned engine over by hand? is this with the crank so you can get a steady revolution? if so then it should blow air out of plug hole with finger over hole. proper check is to use a guage if you want a good reading. did you adjust valves properly? manifold off dont matter. the most probable cause would be valve not seating, or not adjusted or not rotating engine fast enough during check.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
