The head will fit. The M will not be able to use the 450 flywheel and its original Liftall belly pump. The reason is that the M had an 11 inch clutch, the 450 has a 12". The tractor will now have the Live hydraulics of a Late SM/SMTA, if you get the pump with the block. I do not see any reason the original M flywheel would not work. Use a good pressure plate and a new driven disk and all is well. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
