Re: 1066 Kill Switch.
Posted by DB on July 19, 2000 at 16:23:01 from (209.64.155.40):
In Reply to: 1066 Kill Switch. posted by Greg H. on July 18, 2000 at 10:52:57:
Come off the air intake side of blower with an elbow turn up into a short Stack and put a flapper on it like a muffer would have---Rig a spring on the flapper and a pin to hold it open-- cable off the pin to rear of tractor--that cable will hook to sled --if some thing breaks loose--cable pulls pin --spring pulls flapper down --air is shut off-- yes you do have to cut a hole hood to run the short stack thru--
Post A Followup
: Re: Re: 1066 Kill Switch.
