Re: Whats the difference in M's?
Posted by Ludwig on March 11, 2011 at 10:40:45 from (63.209.227.77):
In Reply to: Re: Whats the difference in M's? posted by sflem849 on March 11, 2011 at 07:13:42:
Slightly bigger engine, higher gearing and something else I can't remember off the top of my head.
Actually as I think of it the engine might be the same size but maybe theres more compression or rotational speed, the Super M made a little more power anyway.
I've got a Stage I, 1952, back when my great uncles were still farming they had it and an M. The M got used to push snow, they claimed that with the lower gearing it was better suited for that job than the Super. The Super M got the bush hog as it was a touch faster and could handle heavier cutting more easily although if the cutting was easy they had an H they'd put on the mower because it was easier on gas.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
