Re: Changing the belts on a Super M
Posted by rustyfarmall on March 11, 2011 at 11:47:06 from (209.152.78.140):
In Reply to: Changing the belts on a Super M posted by Wardner on March 11, 2011 at 10:45:02:
That set screw only serves to lock the two pulley halves into place. Loosen the screw, maybe even remove it completely, and then the front half of the pulley can be rotated away from the back half, which will remove tension on the belt. Only thing is, the two halves are most likely pretty well rusted into place, and will not want to move. Heat, penetrating oil, and persistance is in order.
Hint---the owners manual goes into pretty good detail on replacing the belts. It even has pictures.
