Re: farmall 400 hydraulics
Posted by Matt Weltz on March 11, 2011 at 12:37:20 from (173.26.100.72):
In Reply to: farmall 400 hydraulics posted by 53ih on March 10, 2011 at 19:14:53:
While running, does the engine seem bogged down like the pump is working/trying to put out presure? I had that problem on my 300...as previously mentioned, there is a small screen inside the pressure regulator block, if this is plugged or collapsed on itselt (like mine did) it will cause your problem. If this is the case, the pump will also get very hot very quickly while tractor is running.
Was the system full of fluid before you got the tractor? Either way it could also be air locked (also previously mentioned). My 400 did that once to me while changing hoses on the loader. I took the breather tube off the top of the reservior and stuck my rubber tipped air gun in the hole. With the tractor running, give it a little shot of air and the pressure should push the fluid through the lines and the air out.
While you are checking these things, it would be a good idea to throw a wrench on your 3 valves and make sure they are all set to either single or double acting. There are roll pins on the top that is supposed to point to which way they are set but those pins can get bent or twisted...if one of your valves is stuck in the middle it would also cause your problem. That also happened to me on the 300 I had.
