4 ways to turn the engine. The hand crank (if you have one, and the drive snout is free to turn, some are frozen). Push in on the main fan belt and turn on the blades of the fan. Putting it in 5th Direct, and rocking the rear tires forward. Lifting one back tire and turning forward on that. Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
