Re: WD-9 not firing
Posted by meihman on March 12, 2011 at 09:24:03 from (216.46.131.242):
In Reply to: WD-9 not firing posted by plow hand on March 12, 2011 at 09:13:40:
with valve cover off, you will notice a third valve with its own rocker arm. make sure the rocker arm is turning and that the valves are openning and closing. these valves drop the compression. if they are stuck open then it wont fire on diesel. since it is running on gas the valves are not stuck shut. since you are getting fuel at the injectors then there shouldnt be any problems with the linkage from the throttle lever.
