Re: light switch box gets warm???
Posted by Janicholson on March 12, 2011 at 13:35:06 from (67.72.98.45):
In Reply to: light switch box gets warm??? posted by bmagee on March 12, 2011 at 11:03:53:
There are possibly two resistors on the light switch. One is for the dim lights, and is only energized if the lights are on dim.
The other resistor (if it has a 4 position light switch) is used for adjusting the generator output.
It is grounded to the switch body on one terminal, and is connected to a wire going to the generator field terminal if the generator is using a cutout relay and the 4 position light switch.
If it is heating the box, something inside the box is either wired wrong, or shorted to the box.
