Re: Gear Shifter
Posted by sflem849 on March 13, 2011 at 06:50:28 from (69.197.84.192):
In Reply to: Gear Shifter posted by FC Andy on March 12, 2011 at 15:29:18:
Isn't that what the $20 pin does?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
