Re: M Won't stay running
Posted by Janicholson on March 13, 2011 at 16:48:33 from (67.72.98.45):
In Reply to: Re: M Won't stay running posted by frogy on March 13, 2011 at 16:42:43:
It does help. If the Starter relay is a 4 terminal affair. the wire connected to the I small terminal is connected to the coil or resistor on the coil side. This supplies starting voltage to the coil as a bypass (as I was having you do in my post). When the key is turned back to run, this wire is disconnected. Thus the coil is now dependent on the ignition switch and the wire to the resistor, and the resistor. Resistors fail. Jumper it as I indicated, and try it. Jim
