Re: Wood's Brush Hog
Posted by GEO on July 19, 2000 at 20:09:47 from (63.104.132.159):
In Reply to: Wood's Brush Hog posted by Wardner on July 19, 2000 at 16:10:25:
If you torch the center bolt, how were you planning to remove it. If the head of the bolt is to far gone to use a wrench on it, I would cut a hole in a piece of flat steel just big enough to fit around what is left of the center bolt then weld to it. Then use a pipe wrench to turn the flat plate to turn the bolt.
Post A Followup
: Re: Re: Wood's Brush Hog
