Re: 1949 farmall h no power
Posted by Janicholson on March 13, 2011 at 17:38:37 from (67.72.98.45):
In Reply to: 1949 farmall h no power posted by Karl J.r. on March 13, 2011 at 17:18:42:
Does the centrifugal advance work? Use a timing light, or twist a little on the rotor and see if it springs back. Bad advance will do it! Jim
