Re: 504 Wide Front end
Posted by rustyfarmall on March 14, 2011 at 09:08:08 from (209.152.78.140):
In Reply to: 504 Wide Front end posted by Ronald H Mccarty Jr on March 13, 2011 at 14:52:20:
The 504 was a descendent of the Farmall C, 200, 230, 340 etc. The wide fronts from an H will not fit, nor will any of the other models you mentioned.
If you really do want a wide front axle for your 504, I can fix you up with a brand new unit from Schwartz.
