Re: Farmall Super A 1948
Posted by glennster on March 14, 2011 at 10:51:27 from (75.57.126.3):
In Reply to: Farmall Super A 1948 posted by spmason on March 14, 2011 at 10:47:01:
should be better than 90 psi on up over 120 psi. be sure you run the compression test with wide open throttle, all plugs removed. run the test dry, then squirt 4 or 5 pumps of engine oil in each cylinder, roll the motor over a few times to spread it around, then re-run the test.
