Re: Farmall Super A 1948
Posted by wayne in mn on March 14, 2011 at 13:05:50 from (64.118.12.213):
In Reply to: Farmall Super A 1948 posted by spmason on March 14, 2011 at 10:47:01:
Is the Schrader valve core from a tire? Compression testers need a special valve core with a very weak spring. Otherwise your readings will ber very low.
The throttle must be wide open and all spark plugs removed. Also make sure the ignition switch is off.
