Re: IH 504 remote pressure
Posted by TractormanNC on March 14, 2011 at 16:36:57 from (72.251.105.81):
In Reply to: IH 504 remote pressure posted by Pandora 504 on March 14, 2011 at 10:38:11:
"It cuts off at 1250 psi" Do you mean (1) that the lever returns to neutral at 1250 psi or (2) that 1250 psi is all the system will make?
If #1, it is working just as it is supposed to. The lever is supposed to unlatch from detent at about 1250 psi.
If #2, you have other problems. worn out pump, relief valve opening at too low a pressure, pump cavitating etc.
