Posted by D Slater on March 14, 2011 at 19:13:31 from (184.15.39.42):
In Reply to: Re-wiring a Super M posted by 55 50 Ron on March 14, 2011 at 13:44:07:
For that SM serial # the sealed beams were correct. Originaly the sealed beam lights used were made to have part of the sealed beam sticking out the light case rear hole with a screw for attaching the feed wire. Thin ground strap also came out the hole and was mounted under a small screw that threaded into the light case, ground wire of the wire harness connected to that screw. Rear light with the switch on top was considered a optional attachment. One for your tractor should have a screw hole in the case for the ground wire.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
