1947 H Farmall
Posted by James Tabor on July 20, 2000 at 06:35:23 from (206.166.230.5):
Have owned and used a 1947 H Farmall for many years. It has always cranked and started just fine. Recently it takes as much as 45 seconds of cranking to get it started and seems to be getting worse. However once started it runs just fine. It still has the six volt system. I keep fresh gas and spark plugs in it at all time. Any info on what the problem might be. Thanks in advance for any advice.
Post A Followup
: Re: 1947 H Farmall
