Re: int 140
Posted by Jim Becker on March 15, 2011 at 08:47:58 from (173.57.163.253):
In Reply to: int 140 posted by j r roberts on March 13, 2011 at 19:18:35:
The A/B tank won't work on anything later because the sediment bowl will run into the Touch-Control block. The C and the early Super A used the same tank. It was changed for the Super C. The Super C tank was used on later Super As with a different bracket. The Super C tank was used through the 140.
I haven't tried all these combinations. But it appears the later tank will probably work on an early Super A or a C if you have the right bracket. However, the later tractors require a Super C or later tank.
