Re: Farmall M with 12v conversion wont charge.
Posted by old on March 15, 2011 at 12:32:46 from (4.245.14.106):
In Reply to: Farmall M with 12v conversion wont charge. posted by Jasen on March 15, 2011 at 11:33:12:
What happens if you remove the light from the system as in wire around the light?? If it then charges you need a new bulb since bulbs over time can get where they are more resistive and that will cause it to not let the excite circuit of the alternator to work. Also are you just going by the amp gauge and the fact the light does not go out or are you checking battery voltage at the battery both run and not running to make sure you have the 12 or so volts at the battery not running and around 14 volts running??
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
