Re: I have the head off the MD, now what?
Posted by LaBoyteaux on March 15, 2011 at 14:50:00 from (76.14.94.14):
In Reply to: I have the head off the MD, now what? posted by sflem849 on March 15, 2011 at 14:04:16:
Recommend you get a manual which describes the steps to
remove and replace the head. It is not necessary to clean carbon
off the top of the pistons but it is important that the top of the
block and the matching surface of the head are clean. While you
are scraping the top of the block you can keep a vaccum cleaner
running working one hand with the vaccum and the other with
the scraper so loose material is all sucked up. When done
vaccum out each cylinder. Some guys will stuff a rag in the
cylinder to keep chips out but either way use the vaccum.
Are you going to get the head checked for cracks. That is
usually the machine shop unless you have the equipment. Also
need to check that both the block and head have a straight flat
suface, not warped.
I usually make a pair of alignment studs by cutting off the tops
of a couple of old (straight) bolts. Screw them loose into the
block, put on the gasket and carefully lower the head down over
the studs. This keeps the new gasket from slipping out of
position and everything lined up. Start a couple of head bolts
and remove the studs.
The engine can be in any position when you replace the head,
may actually be best that you leave it as it was when you
removed the head. When you bolt the rocker assembly back on
the valve clearance should be pretty near where it was when you
took the head off but to be safe you can back off the adjusters
a little, then turn the engine slowly by hand and readjust each
cylinder at the top of the compression stroke.
Usually you will torque the head once when it is cold and a
second time after it has warmed up. Use a accurate torque
wrench.
