Re: Another M wiring question
Posted by SadFarmall on March 15, 2011 at 15:57:55 from (124.180.108.46):
In Reply to: Another M wiring question posted by Baelee05 on March 15, 2011 at 15:38:16:
Yes, it all sounds good. Principles of wiring are:
Main Terminal of Generator to Main Terminal of Regulator (labelled D or Arm for Armature)
Field Terminal to Field Terminal (labelled F)
The ammeter sounds fine also. The way you have it, the worst that you might do is have the ammeter read backwards. If this happens, just reverse the connections on the back of the meter.
You can't really go wrong with the ammeter unless you do either of:
1). Connect it direct from negative terminal of battery to Earth - will probably set the ammeter on fire
2). Connect starter motor circuit through ammeter - also liable to cause copious release of smoke when you hit the start button
