Re: f 20 crank
Posted by Nebraska Kirk on March 15, 2011 at 19:38:58 from (207.91.4.197):
In Reply to: f 20 crank posted by rogerlab on March 15, 2011 at 19:35:11:
The main bearing is a press fit on the crankshaft. Yes, the flywheel is pressed tight to the rear main bearing. You can take a center punch and make some punch marks around the crank where the bearing goes, this will dimple the metal enough to make the bearing fit tighter.
