Posted by Wardner on March 15, 2011 at 22:01:20 from (209.86.226.21):
In Reply to: Propane Carb posted by Gene Stevens Oh-Tx on March 15, 2011 at 20:05:51:
Sounds like the valve inside the regulator is passing too much liquid propane and it is going to the carb causing condensation of atmospheric water vapor on outside of carb. Liquid propane in the carb is way too rich and will not ignite.
Does it run just using the vapor valve? If so, let it run on vapor until the engine is warm. The liquid side may work after that.
Chances are that you will have to put a kit in the regulator.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
