Re: 2 point to 3 point adapters?
Posted by horsepoor on March 16, 2011 at 05:05:49 from (208.124.126.217):
In Reply to: 2 point to 3 point adapters? posted by El Toro on March 16, 2011 at 03:02:35:
Matt, I know what you mean, and yes that is the way I use mine. With the 3 arms that slide into the I-H fasthitch work, but you can't swing them out very well to get them on the lower pins on the implement. Seems best to use that as well as the 3 point quick hitch to get around the lack of lower mobility on the I_H fasthitch since they were never designed to be used the way we have to now.
-Horsepoor
