Re: 340 stuck in high on T.A
Posted by Janicholson on March 16, 2011 at 07:01:25 from (199.17.6.194):
In Reply to: 340 stuck in high on T.A posted by plow hand on March 16, 2011 at 01:03:05:
If the TA throwout bearing is destroyed, or the fingers on the TA lockup clutch, or the TA clutch disk is rusted to the TA housing or Pressure plate, or the ta internal planetary gears are broken and locked into a single unit from wedged gear teeth, the TA will act like it is alwys in direct. For sure it will require a split. The only possible non split solution is if the TA lever is stuck on its pivot point, or the TA linkage is completely gone or disassembled (obvious). Jim
