If the ring gear backlash is in the area of .007 to .009, I would run it as is. Straight Bevel gears can be adjusted in and out to make the wear pattern slightly different, but not much. .003 more extension of the pinion might makes some difference toward the middle due to fatter teeth moving toward thinner teeth, But the pattern is OK to me. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
