Posted by D Slater on March 16, 2011 at 19:44:25 from (184.15.39.42):
In Reply to: Super MTA vs 400 posted by charlie M on March 16, 2011 at 17:20:58:
Steering supports and throttle linkage, battery boxes, clutch pedal, fuel tanks, air cleaner gas models, IPTO operating handle, radiators and fan shrould, transmission top cover and shift forks, starter, wireing and gage locations. Early F 400 used the same rear cast wheels, t/a operating handle and engine block cast # as a SMTA. later 400 used slightly different parts.
On gas engines the 400 used a different head, manifold, valve cover, camshaft, carburetor, distributor advance set up, and some other small things. Later 400 used different connecting rods, pistons, piston pins, camshaft gear and not to far into production a dipstick in engine block was added.
Diesel engines had very few changes except part of 400 tractors used a B type injection pump and the last few came with open type injectors. Max horsepower tests for a SMD and a F400D were the same or fractions different for the two.
Probably forgot something. Yes gear shifter and generator mounting braket on part of the 400 tractors.
This post was edited by D Slater at 02:43:37 03/17/11.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
