Re: What went wrong on MD?
Posted by BruceS. on March 16, 2011 at 19:49:35 from (76.15.41.252):
In Reply to: Re: What went wrong on MD? posted by sflem849 on March 16, 2011 at 19:18:27:
Thanks for your offer. This was really nagging me so I went out after supper, blocked down the clutch, started the tractor, let it run a few minutes. Motor is fine. Finally got up enough courage to get on the tractor and shift thru the gears. No bad sounds. All good there. Gingerly let the clutch out and backed up about 5 feet. No bad sounds. Tried all forward gears. All seems fine.
Used the tractor all last fall some work and shows.
No problems whatsoever. Parked it in barn for winter. Then today, I start it and tranny locks up. I don't get it. Will investigate further.
