Re: I have the head off the MD, now what?
Posted by Janicholson on March 16, 2011 at 20:10:14 from (67.72.98.45):
In Reply to: Re: I have the head off the MD, now what? posted by sflem849 on March 16, 2011 at 19:24:21:
If it ran fine, I would not get into the head work.
If you know where it leaked exactly, use a very good straightedge to see if there is a low spot on either the head or the block. If so, I would cut a piece of tag board (file folder) just the size of the leaking area and glue it to the low spot with #2 non hardening Permatex on both sides of the paper then put the head gasket on as usual. This should make a good seal in that leak prone location. Mine leaked there! Jim
