Re: Can I rebuild a torque amplifer myself?
Posted by sflem849 on March 16, 2011 at 20:17:43 from (69.197.84.192):
In Reply to: Can I rebuild a torque amplifer myself? posted by Danny D on March 16, 2011 at 19:38:13:
If you can run a machine shop you can rebuild it yourself. If you don't trust yourself, you could always take it to the dealer/a local tractor mechanic for rebuild. The double split is usually the expensive part of the job.
I'm guessing as a machinist you could repair the worn parts better than most people doing the rebuild. Want to do my MD throttle??? :lol:
