Re: + and - on coil
Posted by Bob M on March 17, 2011 at 14:56:47 from (67.240.171.41):
In Reply to: + and - on coil posted by jaybradley on March 17, 2011 at 14:17:04:
Depends on the engine's ground polarity.
If positive ground (most 6 volt systems) the coil - should connect to the ignition switch. The coil + should connect to the distributor.
For a negative ground system (most 12 volt systems, and virtually all 12 volt alternators) the coil connections will be reversed.
However from a practical standpoint, the ignition will work fine even if the coil is connected if the polarity is reversed.
